srf2
Jan 05, 2021Guide
extender suddenly not connecting
I have been using the EX6100 wifi extender for a while now without difficulties. All of a sudden on Saturday I started having difficulties with connecting to any devices (TV, laptop, tablet). I reset...
- Jan 10, 2021
have you tried hardwiring into it for setup using a pc/laptop?
Also, try a different browser
Jan 06, 2021Guru - Experienced User
What router do you have it connected to?
What firmware did you install to the router?
- srf2Jan 06, 2021Guide
I have a Netgear Nighthawk R7200. I had received an email from Netgear re: the firmware update.I logged into the Nighthawk and clicked on the link for the firmware update. I am not sure what the current version of the update is.
I have my Netgear extender EX6100 connected to the Nighthawk R7200.
Hope this will help you to provide me with a solution
Thanks
- plemansJan 07, 2021Guru - Experienced User
Log into the R7200 and the status page should show its firmware.
Same with the extender?
have you tried simply factory resetting both router and extender and doing a fresh install? Sometimes fixes issues after firmware updates.
- srf2Jan 07, 2021Guide
I have the Nighthawk R7200. The firmware update that I have is : V.1.2.0.76_1.0.1
