NickClarke
Mar 31, 2021Follower
Extending WiFi For Wireless Cameras
I need to increase the wifi signal strength of my Reolink wireless camera to my laptop. I have weak wifi areas around my house
Apr 01, 2021Guru - Experienced User
Netgear makes wireless extenders. Or you have the option of switching to a mesh network like netgear orbi.
Tough to recommend something though off limited info.
how big is the home?
What materials are the interior walls made from?
What's your budget?
You can go to WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
to check out the extenders.
Or Wifi Mesh Network - WiFi 6 Mesh System | NETGEAR
for the mesh solutions
