PSMPAGE
Apr 17, 2021Follower
Extending wifi range
Hi Looking to try and extend the Home WiFi to my cabin at the end of the garden, my current fibre router is at the front of the property and I have a EX3700 WiFi extender plugged into the back porc...
Apr 19, 2021Guru - Experienced User
You can try that route. In theory it should work (provided the ethenet run isn't to long).
You'll set the 2nd ex3700 to run in access point mode.
You could also use a mesh system like netgear orbi or the MK series. They're a mesh system so support seamless roaming and wired backhaul.
