presydent
Dec 05, 2022Aspirant
Extending WNDR4500v2
Can I extend the range and speed of my Netgear Model WNDR4500v2? For example, using my cellphone within my home I obtain speeds as low as 61mbps and up to 175mbps. I would prefer obtaining the highe...
Dec 05, 2022Guru - Experienced User
Instead of expanding the range, I'd look at upgrading.
Thats a pretty old wireless N router.
There's much newer technology with faster speeds/better performance.
How big is the home? You might even look at switching to something like a mesh system with satellites if you're needing more coverage.
