kpickens24
Dec 23, 2020Follower
External USB storage not working on R7800
I have had constant issues with getting USB storage to work on my R7800 Nighthawk. I was able to access it for a while through the windows file explorer by typing in the IP address but my computer to...
panki123
Dec 23, 2020Aspirant
I'm having similar issues. Up unitl few months back, I was able to use both USB ports (1TB WD drive and 2TB WD drive). After a certain FW update, I do not recall which version ,USB ports no longer work.
I've done factory reset as well as updated to latest FW(*.78 version) but no luck so I've asked netgear support to issue RMA. I've spent multiple hours chasing down tech support agents. L1 agents are useless IMO.
someone really messed up in FW update !!
