rikity
Apr 05, 2017Aspirant
extremely slow donwnload
20 days out of warranty my download speeds have dropped to 3.04 mbps wirelessly. Upload is 11 mbps i have reset the router back to factory settings, disabled wmm and checked the mtu and still have t...
DexterJB
Apr 12, 2017NETGEAR Moderator
Hi rikity,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
rikity
Apr 12, 2017Aspirant
Yes still having the problem. I downloaded the frimware, plugged my laptop into the router with a cat5 and did everything just you described. When I clicked install a warning popped uo saying that I was installing the same firmware, did I want to proceed. I clicked yes and installed it. After the router initialized my download spped dropped to .15 mbps. Any additional ideas?
