Skrillz
Dec 05, 2022Follower
EZ2700 doesn’t connect
I have seen other people have this problem, but none of the solutions have worked for me, I will copy paste one of them since they explain it perfectly. Extender is 2 feet away from my router. When ...
Dec 06, 2022Guru - Experienced User
I don't know where you copied it from but it wasn't a very that good of one you should copy it. And if its the exact same issue, what fixed it for the other person?
What router are you connecting it to?
Did you try using wps?
Or did you try the installation assistant?
If you set it up using the push button WPS option then factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
