Foresthill
Apr 21, 2017Tutor
Factory reset after firmware upgrade
I have had my R6300 for over three years and have always installed firmware upgrades when they become available. I have always used the router itself to do the download and have NEVER done a reset t...
- Apr 21, 2017
Yeah, it's unfortunate that Netgear hasn't updated their configuration system to deal with this. Since a lot of consumer grade router firmware are derived from a common codebase, I would not be surprised if other vendors have the same problem. Not all do. I believe there is at least one that has bitten the bullet and fixed this problem.
Unfortunately, with Netgear you are stuck for now with doing the factory reset. Worse, you can't rely on the backup file to restore from because it will be based on the previous version, so it may be incompatible. There is a chance that you can get away without doing a reset if you don't use a feature that was subjected to the change. A lot of people take this chance. YMMV.
tikithecat
May 08, 2017Aspirant
I cannot believe this! I have been a repeat customer for years. Never again. I am just an old lady,this tech stuff is hard anyway. can you guys recommend what brand I ought to get to replace this-
michaelkenward
May 08, 2017Guru - Experienced User
What's your problem?
You have jumped in on the end of an ageing discussion.
