Jorge612
Nov 04, 2015Aspirant
Factory Reset And Range Extenders
I have a wifi router in one room and a wifi extender in another room. If I do a factory reset on my main router how does that affect my wifi range extender? Do I have to do a factory reset on both pr...
- Nov 05, 2015
Ooh ok I understand now. So as long as I keep things the same such as SSID and password etc. after the reset then the Extender will follow the reset router's settings and move smoothly.
Babylon5
Nov 04, 2015NETGEAR Employee Retired
If you factory reset the router then all its settings will return to default values. The important ones relating to the extender are the wireless settings, SSID and Passphrase/encryption method. If these are set to the same settings as when the extender was set up then the extender should re-connect, at worst it would need to be power-cycled.
The manual for your extender should have been provided on an accompanying CD/DVD, but it is also available by following the ‘Download’ link at the top of this page.
- Jorge612Nov 05, 2015Aspirant
What about my Wireless Router (main hub)? Ever since I did a firmware update its been acting bizarre. I read somewhere that if I reset after an update the update remains and that its actually important to reset to factory settings after an update. So if I reset my Wireless Router, do i have to do a separate reset for my Range Extender too? Or will one stone kill two birds?
- Babylon5Nov 05, 2015NETGEAR Employee Retired
It’s as I posted above, if you factory reset the router the extender is not affected if you re-enter the wireless settings for the router setup. You don't have to reset the extender also.
