Jorge612's avatar
Jorge612
Factory Reset And Range Extenders
I have a wifi router in one room and a wifi extender in another room. If I do a factory reset on my main router how does that affect my wifi range extender? Do I have to do a factory reset on both pr...
  • Jorge612's avatar
    Jorge612
    Nov 05, 2015
    Ooh ok I understand now. So as long as I keep things the same such as SSID and password etc. after the reset then the Extender will follow the reset router's settings and move smoothly.
