Kat101
Dec 22, 2022Follower
Factory reset N750 router, says wifi password is wrong?
I can see both wifi networks available (main and guest) but I get a wrong password error when trying to connect to either network? I tried password and also tried the old password I set up, but neithe...
michaelkenward
Dec 24, 2022Guru - Experienced User
For more help with your "N750" you might like to track down the manual. N750 is a now somewhat ancient wifi technology – the first N750 dates back to around 2010 – rather than a model number. So you'll have to look at the label on the thing to see what it really is.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
