Jrosey
Jan 27, 2021Initiate
Factory Reset Nighthawk X6
My internet provider had me reset my router today since my night app was stalled out and would complete firmware update. We got that all working and up and going but when I went to turn on my computer it won’t connect to wifi. It doesn’t even show a wifi option under status with no available networks. When I run the troubleshooter, it says there is an error with wifi adapter which I have disabled, restarted, enabled. My wifi network adapter is Killer (R) wi-if 6 Ax1650x (200NGW) which I can update without internet. Can anyone tell me how to fix this pretty please???
It worked!! Thank you so much.
So everything else sees the wifi and connect/use it?
You can manually download the driver on a different pc from killer and uninstall/install it.
You could also contact killer since it seems to be an issue with their card if everything else works.
- JroseyInitiate
