Hamish13's avatar
Hamish13
Follower
Jul 24, 2021
Failed firmware update D6400
Hello,
Any advise with failed firmware update.
Current firmware version is 1.0.0.102.
Download version 1.0.0.104 and selected the .chk file via the admin menu and after a
few seconds, I got an error message stating wrong file for router.
How can it be the wrong file, as I download it from the Netgear support page for the D6400?
Any ideas what I can do to update to version 104?
1 Reply
  • > How can it be the wrong file, [...]
       If you really have a D6400, and you're really trying to load it with
    "D6400-V1.0.0.104_1.0.104.chk", and it complains, then it would appear
    that either the firmware image file is bad, or else the current firmware
    is corrupt enough that it can't tell right from wrong.
       I'd try again with some different firmware version (such as what it
    already has).  When that fails similarly, you might want to explore
    using the TFTP recovery scheme to cram a firmware image down its throat.
    See, for example:
          https://community.netgear.com/t5/x/x/m-p/1622096#M102004
       No bets on whether that'll actually work.
