DanielHowden
Oct 30, 2016Aspirant
Failing to setup N300 as a wiFi extender
Hi, I have an N300 wireless router that I would like to use to extend the wireless network at the other end of our house. I have a couple of TLink home plugs that I am using and I have set the route...
- Retired_MemberOct 30, 2016
http://www.practicallynetworked.com/networking/convert_wifi_router_to_access_point.htm
read
Performing the Conversion
DanielHowden
This is my router - I thought it may help.
Thanks, Daniel.
read
- sktn77aOct 30, 2016Virtuoso
Have you plugged the powerline adapter into the WAN port of the router or the LAN port? Older routers apparently nrrd to be connected via the LAN port while newer oned use the WAN port. Also, check your router's DHCP is disabled.
