DanielHowden
Oct 30, 2016Aspirant
Failing to setup N300 as a wiFi extender
Hi, I have an N300 wireless router that I would like to use to extend the wireless network at the other end of our house. I have a couple of TLink home plugs that I am using and I have set the route...
- Retired_MemberOct 30, 2016
http://www.practicallynetworked.com/networking/convert_wifi_router_to_access_point.htm
read
Performing the Conversion
DanielHowden
Oct 31, 2016Aspirant
Hi Keith, I'm not really sure. I had been trying for some time to get it to work and I had followed several tutorials. So before I followed the suggested tutorial I took the time to reset the router to factory.
It was probably me just being a dummy! :)
ElaineM
Nov 07, 2016NETGEAR Employee Retired
DanielHowden Kindly mark the solution so that others can benefit from it as well.
Thank you!
