Camshaft700
Oct 24, 2021Guide
Failure Connection (Honeywell WIFI Thermostat)
Dear netgear community Orbi system Honeywell thermostat wifi Keep getting error code wrong PWord Searching the internet I found a bunch of netgear forum post about 2.4g. How the device your ...
- Oct 26, 2021I can’t edit my first post to add the solution. No special characters can be used (SSID)
So some interesting information
- yesterday thermostat would join iPhone hotspot named “iPhone”
- today thermostat would not join SSId with & symbol in it.
- removed & and the thermostat connects.
I found this information below on the internet.
Honeywell thermostat invalid wifi password
If you’re receiving invalid wi-fi password error when you try to connect to Wi-Fi, please confirm the following:
No special characters have been used in your WiFi network name (SSID) – reset and rename it if necessary.
Oct 25, 2021Guru - Experienced User
I have a honeywell t5 that joined my RBK750 without issue.
Camshaft700
Oct 25, 2021Guide
Thanks I wish I could say the same.
Unfortunately I’m not the only person that has had this issue.
Mine is rrbk50
And RTH6580WF1006/W
Mine is rrbk50
And RTH6580WF1006/W
- Camshaft700Oct 25, 2021GuideNot sure if I can use a old router and turn it into a access point ?
Connect that to orbi and run the thermostat off the AP ?
Seems petty sad but since the thermostat connects to my phone. It’s clearly a orbi issue - plemansOct 25, 2021Guru - Experienced User
Try setting up a phones hotspot with the same ssid/password as the router. Then shut off the orbi, setup the thermostat with the hotspots ssid (same as mesh systems ssid). Once setup, shut off the hotspot and turn on the router.
- Camshaft700Oct 25, 2021GuideI guess I will have to shut down the orbi system.
Then set my phone as the hotspot with the same pw and ssid.
See if it will connect to the hotspot , then turn hotspot off and turn orbi on
They that tonight - Camshaft700Oct 26, 2021GuideI can’t edit my first post to add the solution. No special characters can be used (SSID)
No special characters have been used in your WiFi network name (SSID) – reset and rename it if necessary. - plemansOct 26, 2021Guru - Experienced User
glad it was a simple fix! Thanks for getting back to us on what fixed it
