Camshaft700
Oct 24, 2021Guide
Failure Connection (Honeywell WIFI Thermostat)
Dear netgear community Orbi system Honeywell thermostat wifi Keep getting error code wrong PWord Searching the internet I found a bunch of netgear forum post about 2.4g. How the device your ...
- Oct 25, 2021I can’t edit my first post to add the solution. No special characters can be used (SSID)
So some interesting information
- yesterday thermostat would join iPhone hotspot named “iPhone”
- today thermostat would not join SSId with & symbol in it.
- removed & and the thermostat connects.
I found this information below on the internet.
Honeywell thermostat invalid wifi password
If you’re receiving invalid wi-fi password error when you try to connect to Wi-Fi, please confirm the following:
No special characters have been used in your WiFi network name (SSID) – reset and rename it if necessary.
Camshaft700
Oct 25, 2021Guide
Oct 26, 2021Guru - Experienced User
glad it was a simple fix! Thanks for getting back to us on what fixed it
