Camshaft700
Oct 24, 2021Guide
Failure Connection (Honeywell WIFI Thermostat)
Dear netgear community Orbi system Honeywell thermostat wifi Keep getting error code wrong PWord Searching the internet I found a bunch of netgear forum post about 2.4g. How the device your ...
- Oct 25, 2021I can’t edit my first post to add the solution. No special characters can be used (SSID)
So some interesting information
- yesterday thermostat would join iPhone hotspot named “iPhone”
- today thermostat would not join SSId with & symbol in it.
- removed & and the thermostat connects.
I found this information below on the internet.
Honeywell thermostat invalid wifi password
If you’re receiving invalid wi-fi password error when you try to connect to Wi-Fi, please confirm the following:
No special characters have been used in your WiFi network name (SSID) – reset and rename it if necessary.
Radarshe
Jun 23, 2022Aspirant
You nailed it!!!! My Nughthawk/Honeywell thermostat connections was lost several weeks ago. Honeywell couldn't help. Netgear also couldn't figure out why my "password(E02 code) was incorrect. Honeywell sent a new thermostat. Ince again Honeywell & Netgear couldn't figure out the issue. I tried in total 3 thermostats(2 new) & two routers(1 new) with the same result. Netgear finally suggested getting a different thermostat because of compatibility problems. I followed the guidance of the original poster & removed any characters that were not a letter or a number. Voilá it worked!!!! Thanks a bunch.
