Sjp613
Apr 30, 2023Aspirant
Failure to reach close to advertised speeds.
I have an 1750 AC router R6400V2. I just increased my internet speed to 1GHZ through my ISP. The device doesn’t get close to advertised speed either via Wi-Fi or Ethernet. If I hook my computer direc...
michaelkenward
Apr 30, 2023Guru - Experienced User
Did you reset and reconfigure the router after the upgrade? It may be running on settings designed for the old Internet service.
If I hook my computer directly to the new new modem I get close to 1GHZ.
And that modem is?
Wi-Fi much slower than expected.
Only you know what speeds you "expect" – ignore the marketing guff – but in general these will be a lot lower than the Internet speed. The wifi clients fix the wifi speed, not the router or the Internet connection.
Power light is not white. See attachment
I see no attachment. Not "white" can be a sign of hardware failure or a dying power adapter.
Be warned that your R6400V2 is based on a device first sold in 2015 and was never an "advanced" router. It was launched in an era when Gb Internet was almost unknown.
Netgear, and other brands, have been through several technology generations since then
