Sjp613
Apr 30, 2023Aspirant
Failure to reach close to advertised speeds.
I have an 1750 AC router R6400V2. I just increased my internet speed to 1GHZ through my ISP. The device doesn’t get close to advertised speed either via Wi-Fi or Ethernet. If I hook my computer direc...
Sjp613
Thanks. You confirmed what I suspected. I was going to look for an upgrade soon so I will temporize in the meantime. Any suggestions about a replacement that will not be terribly expensive. I am not a gamer. Usually only have smart TV, tablets and iPhones using system.
May 01, 2023Guru - Experienced User
What modem/gateway is it connected to?
If its a new upgrade, factory reset the R6400. Don't install it from a backup and make sure during the reinstall to leave qos, access controls, parental controls, and traffic monitoring all disabled. They'll slow your speeds on that device.
What firmware version are you on?
You're not going to get great speeds out of that device or any of the AC1750/AC1900 devices but this review will give you a rough idea of what they're capable of.
https://www.smallnetbuilder.com/wireless/wireless-reviews/netgear-r6400-wireless-retest/
