DERoss's avatar
DERoss
Apprentice
Dec 05, 2021
False "Not Connected"
Windows 7 Ultimate SP1 x64
Netgear router WNDR3400v3
Router firmware version:  V1.0.1.42_1.0.68
Router GUI version:  V1.0.1.24_2.1.28.1
When I logged in to the GUI to update the firmware, I noticed that the status was "Not Connected".  Having just downloaded the ZIP file of the firmware, I knew that was not true.
I installed the new firmware, which involved an automatic reboot of the router.  The status remained "Not Connected".  However, an application that uses the Internet showed a good connection.  I manually disconnected my PC from the router and reconnected.  I still get "Not Connected".  However, I am posting this through a connection via that router.
Also, the indicator lights on both the router and my non-Netgear modem both indicate I am indeed connected.  The router is only one year old.
  • SOLVED.
    I logged onto the Netgear GUI and went to [Advanced > Setup Wizard].  I seletected the Yes radio button and then the Next button.  When requested for a new password, I entered my existing (not default) password.  When that process finished, the Interent status was Good.  I finished by saving my settings.
    Yes, my modem is old, 5 years old; but it still works fast enough for me.  And my router is relatively new, only 1 year old.  Until one of them dies, I do not see a need to replace either of them.
  • I shut down my PC, powered-off the router, and then powered-off my modem.  I waited about a minute and then reversed that.  I still get "Not Connected".
    I then logged onto the router's GUI.  At [Basic > Internet}, I selected the Test button.  I got "Success".  The log at [Advanced > Administration > Logs] says that I am connected.
    While I am indeed connected and having no problems using the Internet, I am concerned that there appears to be a problem with my router.
    • plemans's avatar
      what actual modem/gateway is the router connected to?
      • DERoss's avatar
        DERoss
        Apprentice
        Modem:  Motorola MB7220 V1.0
        Modem firmware version:  7220-5.7.1.9
