gheinrich
Feb 05, 2017Aspirant
Fast connection not showing on devices
The faster connection only shows on mobile devices. Have had this router connected for about a year successfully, suddenly would only show the slow connection option. Changed all SSID names and passw...
- Feb 06, 2017
Hi gheinrich,
1. What is the model number and firmware version of the router?
2. Are you referring to the 5GHz band (fast) and 2.4GHz (slow) band?
3. Please make sure that "Enable SSID Broadcast" option is checked for the 5GHz band.
4. Please make sure your non- mobile devices support the 5GHz band.
Dexter
Community Team
DexterJB
Feb 06, 2017NETGEAR Moderator
Hi gheinrich,
Dexter
Community Team
- DexterJBFeb 09, 2017NETGEAR Moderator
Hi gheinrich,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- gheinrichFeb 24, 2017Aspirant
I am working on how to find out if my computer recieves 5 gig wifi? I could swear it does because when we first got this router it was FAST. Now it will only recognize the slow connection for some reason.
