gheinrich's avatar
gheinrich
Fast connection not showing on devices
The faster connection only shows on mobile devices. Have had this router connected for about a year successfully, suddenly would only show the slow connection option. Changed all SSID names and passw...
  • DexterJB's avatar
    Feb 06, 2017
    Hi gheinrich,
    1. What is the model number and firmware version of the router?
    2. Are you referring to the 5GHz band (fast) and 2.4GHz (slow) band?
    3. Please make sure that "Enable SSID Broadcast" option is checked for the 5GHz band.
    4. Please make sure your non- mobile devices support the 5GHz band.
    Dexter
    Community Team
