MUGWAMPBRO
Dec 24, 2019Aspirant
Fastlane Options ?????
When you enable FastLane Technology, you have two options: Use the 2.4 GHz band to connect the extender to the Wi-Fi devices and use the 5 GHz band to connect the extender to the Wi-Fi router. Use t...
- Dec 26, 2019
OK.....Thanks for your time !!!!
antinode
Dec 25, 2019Guru
> [...] the extender [...]
I'll bite. What, exactly, are you reading/quoting? What, exactly,
is "the extender"? What are you doing?
- MUGWAMPBRODec 25, 2019Aspirant
"When you enable FastLane Technology.............." is a quote from netgear's wersite.(https://kb.netgear.com/24662/What-is-FastLane-Technology-and-how-do-I-configure-it)
There are 2 options available when you enable/install FastLane.
I live in a cottage about 150yds. from my Netgear router and am trying to improve my wi-fi signal with an ALFA wifi extender (awus036ach). The ALFA extender works quite well but there is always room for improvement.
The 2.4 GHz signal has a much better "throw" (distance wise) than the 5 GHz signal.
I want to try both Options to see which one works best for my situation, but I can't find the options on Netgear Genie. HELP !!!
Thanx for the reply
- antinodeDec 25, 2019Guru
> [...] https://kb.netgear.com/24662 [...]
Read the "This article applies to:" stuff on the right side of that
KB article.> [...] I can't find the options on Netgear Genie. [...]
Because you don't have any device (extender) which has those options?
I can find plenty of other Netdear KB articles which don't apply to
your gizmos, too. (Pick a number, (almost) any number.)- MUGWAMPBRODec 25, 2019Aspirant
I guess you are saying I need to use a NETGEAR extender. I enabled FASTLANE (netgear genie) and it did improve the speed and quality of my Alfa extender !! I guess I will only have the 2 options to experiment with if I purchase a NETGEAR extender.... That sucks.... maybe somebody knows of a work around for the Alfa extender? For now I will just be glad for the additional boost. :)
