MUGWAMPBRO's avatar
MUGWAMPBRO
Fastlane Options ?????
When you enable FastLane Technology, you have two options: Use the 2.4 GHz band to connect the extender to the Wi-Fi devices and use the 5 GHz band to connect the extender to the Wi-Fi router. Use t...
  • MUGWAMPBRO's avatar
    MUGWAMPBRO
    Dec 26, 2019
    OK.....Thanks for your time !!!!
