Darkness7148
Mar 26, 2017Aspirant
File not found in network drive.
I recently bought the Netgear D7000 router. I'm trying to setup readyshare with my USB drive so I can access it in Windows. It appears there and I can access files but there is this one folder, all t...
- Mar 26, 2017
I've fixed it now. The files were all read only which for some reason caused the no file found errors over the network drive. So I plugged it in directly and removed the read only flag.
schumaku
Mar 26, 2017Guru - Experienced User
The 3rd party NTFS (and HFS/HFS+/FAT32/...) drivers allow read (and write) access to almost everything on these disks, regardless of mot permission settings.
Start with a file system check (assuming it's an NTFS file system) with the HD plugged to a Windows system.
Darkness7148
I connected it directly to the computer and I can access the files just fine. There doesn't seem to be any permission problems there. There's no file errors either. Just can't seem to access them when it's plugged into the router.
- Darkness7148Mar 26, 2017Aspirant
- michaelkenwardMar 26, 2017Guru - Experienced User
Permissions then, or a variant thereof.
Well fixed.
- schumakuMar 26, 2017Guru - Experienced User
Darkness7148 wrote:I've fixed it now. The files were all read only which for some reason caused the no file found errors over the network drive. So I plugged it in directly and removed the read only flag.
This would be a bug (lack of details I going to assume it's NTFS). A read-only file must not be hidden or inaccessible. ElaineM please take care.
