Darkness7148's avatar
Darkness7148
File not found in network drive.
I recently bought the Netgear D7000 router. I'm trying to setup readyshare with my USB drive so I can access it in Windows. It appears there and I can access files but there is this one folder, all t...
  • Darkness7148's avatar
    Darkness7148
    Mar 26, 2017
    I've fixed it now. The files were all read only which for some reason caused the no file found errors over the network drive. So I plugged it in directly and removed the read only flag.
