BlueDog49
Jun 07, 2021Follower
Fios compatibility
Which router would be compatible with Fios internet/ phone/ cable?
I currently have a Fios gateway router which I want to replace.
1 Reply
BlueDog49 wrote:
Which router would be compatible with Fios internet/ phone/ cable?Your ISP is in the best position to know what devices work on its network. Tell people which ISP it is and they may be able to tel; you what they use.
If you go down that road, try a more appropriate section of this community. This place is for General WiFi Routers (Non-Nighthawk). They have nothing to do with modems.
Then there are the product Netgear pages.
