bmartin024
Sep 13, 2022Follower
Firmware issue on model R6080
Is anyone else having issues with the last firmware update for the model R6080? It was corrupt and had rendered my router useless. Power cycle does nothing and will not factory reset. Green power ligh...
Sep 14, 2022Guru - Experienced User
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
