Robt2021
Jul 10, 2021Follower
firmware unavailble for wndr3400v3
re wndr3400v3 firmware upgrade. I was informed by e-mail that a firmware upgrade is available. (V1.0.1.38?). My current version is V1.0.1.24. I followed the instructions for "checking" if firmware is...
antinode
Jul 10, 2021Guru
> re wndr3400v3 firmware upgrade. [...]
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
When that fails because of a deficient User Manual, try:
> [...] I followed the instructions [...]
_Which_ "the instructions"?
> [...] the response is that there is NO firmware available.
Trust no one, I always say.
