Vegasdealer
Nov 01, 2020Tutor
firmware Update 2.5.1.22 to 2.6.1.36
On my RBR 40 in my Orbi ios app finally showed firmware update.......says firmware update successful and then the apps says connecting with the Orbi device and then nothing. Tried this update several...
- Nov 07, 2020
Sorry for the typo......that was " Why Didn't NetGear just say that. BS Degree and never a great speller, but can figure really well. lol Would have corrected it but unable to find where and or how after posting.
Thank you for your Patience everyone.
antinode
Nov 01, 2020Guru
> Any suggestions [...]
Try using a web browser instead of some (unspecified) "the app"? Try
reading the instructions? Try following previous advice?
Vegasdealer
Nov 06, 2020Tutor
I have read the instructions online. In the app it says "update successful" then the next screen says "Connecting to Orbi" which does not do and the update is not on the router, which it does not, and then shows " 'update'.
- antinodeNov 06, 2020Guru
> I have read the instructions online. [...]
Thanks for the helpful link. I'll just do a Web search for "the
instructions online", and discover what you were reading, and what you
did, shall I?> [...] In the app it says [...]
> [...]Are you reading any of this stuff, or am I just writing for my own
amusement?- VegasdealerNov 06, 2020Tutor
Thank you for your help. WOW, out of trial and error, and most of the help pages gave good information about the file .img.
Online at orbilogin.net on line took a chance and just uploaded the disk image. Guess what, the router updated. Why Netgear just did say to do that in the first place is beyond me not to mention it never worked in the app.
A lot of consumers are just consumers and NOT IT Administrators or can read tech jargon. Netgear, speak in plain English!
Actually, was surprised that it worked!
Again thank you for your time.
Good to you from Las Vegas, Nevada
> [...] Why Netgear just did say to do that in the first place is beyond
> me not to mention it never worked in the app.I'd guess that they believe that a flashy app sells better than a
web-browser interface. (The web-browser interface is not always
bug-free, either, but it's different, hence worth a try.)> [...] Netgear, speak in plain English!
"plain" and "helpful" are spelled differently for a reason.
What could go wrong? (Thanks for the report, in any case.)
