Hammerhead11111's avatar
Oct 05, 2017
Firmware update email wndr 4500
I got a email today to update my firmware on my wndr4500 for security reasons. After the update the Router no longer functions. I cant even login to it to it to downgrade the firmware. This update ha...
  • Hammerhead11111's avatar
    Hammerhead11111
    Oct 06, 2017
    Thats not waht I was told. While holding in the rest button then power on ur router lights will blink. It worked for me. I did a lot of research on this problem. My router had a blinking greeen power light. This indicates a curupt firmware issue. I found a fix this is what I did.
    change ipv4 ip use the following ip 192.168.1.2
    download tftp2
    Enter 198.162.1.1 for server
    pasword for router =password
    Browse to ur path where the firmware u want to use is located.
    Click update.
    I was able to do this and fix my wndr4500. Im I happy I had to do extra work to fix this not at all
