Hammerhead11111
Oct 05, 2017Tutor
Firmware update email wndr 4500
I got a email today to update my firmware on my wndr4500 for security reasons. After the update the Router no longer functions. I cant even login to it to it to downgrade the firmware. This update ha...
- Oct 06, 2017
Thats not waht I was told. While holding in the rest button then power on ur router lights will blink. It worked for me. I did a lot of research on this problem. My router had a blinking greeen power light. This indicates a curupt firmware issue. I found a fix this is what I did.
change ipv4 ip use the following ip 192.168.1.2
download tftp2
Enter 198.162.1.1 for server
pasword for router =password
Browse to ur path where the firmware u want to use is located.
Click update.I was able to do this and fix my wndr4500. Im I happy I had to do extra work to fix this not at all
michaelkenward
Oct 06, 2017Guru - Experienced User
Tried checking the IP address with ipconfig? Routers don't always pick the default.
Have you restarted the whole network, including the modem, in the right order?
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
Hammerhead11111
Oct 06, 2017Tutor
Yes multiple times. Im pretty good configuring my network. I can normally figure out when I run into issues. After this last update the router no longer works properly. If you connect ur router directly to ur PC u should be able to login to it with 198.162.1.1 or the web adrees routerlogin. Ping will aslo tell u the ip its using.
2.4/5ghz led light will not turn on
Can not ping the router to find what its ip is.
I already purchased a new router. Netgear lost me as a cutomer and respect for doing a release that can have such dire results. .
- michaelkenwardOct 06, 2017Guru - Experienced User
Forgive me, I do not speak gibberish, so I find it hard to read what you are saying.
So, let's narrow it down.
Hammerhead11111 wrote:
Yes multiple times.
What, multiple times? Hardware reset?
If you connect ur router directly to ur PC u should be able to login to it with 198.162.1.1 or the web adrees routerlogin. Ping will aslo tell u the ip its using.Several problems in there. The addresses 198.162.1.1 and routerlogin are not the only possibilities.
Ping will not tell you the IP address.
I suggested using ipconfig to get the IP address, an easy one for someone pretty good at configuring a network. That might have revealed the correct ip address for the router.
But you have now moved on to a different brand. One warning, though, many router makers use the same approaches to accessing their hardware. Hope you never hit problems there too.
- Hammerhead11111Oct 06, 2017Tutor
download tftp2
As I explained when you posted exactly the same information elsewhere, whichever unknown person told you that was wrong.
Re: Locked out after Nighthawk firmware update - NETGEAR Communities
Press the reset button when the router is turned on. The manoeuvre you describe is for a different, more drastic, reset process.
As before, I mention this only to warn people that this information is suspect. The sledgehammer approach can be dangerous. There may be simpler ways of fixing this problem.
