Hammerhead11111
Oct 05, 2017Tutor
Firmware update email wndr 4500
I got a email today to update my firmware on my wndr4500 for security reasons. After the update the Router no longer functions. I cant even login to it to it to downgrade the firmware. This update ha...
- Oct 06, 2017
Thats not waht I was told. While holding in the rest button then power on ur router lights will blink. It worked for me. I did a lot of research on this problem. My router had a blinking greeen power light. This indicates a curupt firmware issue. I found a fix this is what I did.
change ipv4 ip use the following ip 192.168.1.2
download tftp2
Enter 198.162.1.1 for server
pasword for router =password
Browse to ur path where the firmware u want to use is located.
Click update.I was able to do this and fix my wndr4500. Im I happy I had to do extra work to fix this not at all
beachbaby
Oct 06, 2017Aspirant
Trying to update firmware. Got a pop up saying authentication required, but it also said that my connection with the site is not private! Why update firmware if it's not private? This doesn't make sense to me.
- michaelkenwardOct 06, 2017Guru - Experienced User
Where did you see this popup and warning?
Could it be your browser and its security settings? Netgear has no control over that.
- beachbabyOct 06, 2017Aspirant
It popped up in google. How can I update without being at risk?
Download from the web site and apply manually.>>>>> WNDR4500 | Product | Support | NETGEAR <<<<<
The release notes explain what to do:
WNDR4500 Firmware Version 1.0.1.46 | Answer | NETGEAR Support
Then again what does "in google" mean. Chrome? Google search? Something else?
