Hammerhead11111
Oct 05, 2017Tutor
Firmware update email wndr 4500
I got a email today to update my firmware on my wndr4500 for security reasons. After the update the Router no longer functions. I cant even login to it to it to downgrade the firmware. This update ha...
- Oct 06, 2017
Thats not waht I was told. While holding in the rest button then power on ur router lights will blink. It worked for me. I did a lot of research on this problem. My router had a blinking greeen power light. This indicates a curupt firmware issue. I found a fix this is what I did.
change ipv4 ip use the following ip 192.168.1.2
download tftp2
Enter 198.162.1.1 for server
pasword for router =password
Browse to ur path where the firmware u want to use is located.
Click update.I was able to do this and fix my wndr4500. Im I happy I had to do extra work to fix this not at all
DrRussKennewick
Oct 23, 2017Aspirant
I just had the same experience when I used Genie to update my firmware on my WNDR4500. I have updated several times previously on this router with no incidents. HOWEVER, this time, the update corrupted my eprom, and I now have a bricked router. I get the flashing green power light and have no way, that I am aware of, to save this 5 year old router from extinction. So, my word of advice is, be aware that even if you do everything correctly, and use Netgear software, you still run the risk of turning a perfectly functioning, albeit dated, router into a beautiful plastic paperweight.
Hammerhead11111 wrote:I got a email today to update my firmware on my wndr4500 for security reasons. After the update the Router no longer functions. I cant even login to it to it to downgrade the firmware. This update has in effect bricked my router. Is there any way to recover from such a stupid error that Netgear caused.
- michaelkenwardOct 23, 2017Guru - Experienced User
Bummer. Did you see this?
How to resolve amber LEDs or a blinking power LED on NETGEAR routers | Answer | NETGEAR Support
- DrRussKennewickOct 24, 2017Aspirant
No, I hadn't seen that post. I have downloaded the info and will give it a shot. This will be the second time I have pulled this router out of the trash can in the last two three days.. LOL. Thank you for bringing this to my attention. ITMT, I did replace this router with a Nighthawk AC2300, but if I can salvage my WNDR, I know of a good home.. :)
michaelkenward wrote:Bummer. Did you see this?
.- michaelkenwardOct 24, 2017Guru - Experienced User
Good luck. You may need it.
AC2300 isn't a Netgear model number. Do you mean the R7000P?
