fourdoor2041
Jun 21, 2017Aspirant
Firmware update email
I received an email to update my firmware. When I went into the Admin section of my Netgear Genie to check for new firmware there was no firmware available. I would suggest to anyone who use the Ne...
- Jun 22, 2017
All firmware updates can also be seen and downloaded from our support site.
Once you have selected your exact model number then click on "Downloads", scroll a little bit to look at the "Firmware and Software Downloads list".
ElaineM
Jun 22, 2017NETGEAR Employee Retired
- StanLenciJun 22, 2017Aspirant
ElaineM.
Just curious. Same situation for my R6700 AC1750 Nighthawk, received email notification of new firmware but when I login to my router and click Advanced/Admin/Update to have my router check for the update, it says no update exists. Can download and update but not update via the router update feature. Why?
