fourdoor2041
Jun 21, 2017Aspirant
Firmware update email
I received an email to update my firmware. When I went into the Admin section of my Netgear Genie to check for new firmware there was no firmware available. I would suggest to anyone who use the Ne...
- Jun 22, 2017
All firmware updates can also be seen and downloaded from our support site.
Once you have selected your exact model number then click on "Downloads", scroll a little bit to look at the "Firmware and Software Downloads list".
ElaineM
Jun 22, 2017NETGEAR Employee Retired
StanLenci
Jun 22, 2017Aspirant
ElaineM.
Just curious. Same situation for my R6700 AC1750 Nighthawk, received email notification of new firmware but when I login to my router and click Advanced/Admin/Update to have my router check for the update, it says no update exists. Can download and update but not update via the router update feature. Why?
