fourdoor2041
Jun 21, 2017Aspirant
Firmware update email
I received an email to update my firmware. When I went into the Admin section of my Netgear Genie to check for new firmware there was no firmware available. I would suggest to anyone who use the Ne...
- Jun 22, 2017
All firmware updates can also be seen and downloaded from our support site.
Once you have selected your exact model number then click on "Downloads", scroll a little bit to look at the "Firmware and Software Downloads list".
tlto
Jun 30, 2017Aspirant
I tried to follow the directions for this firmware upgrade but ran into an issue when asked "the server....is asking for your user name and password". I don't know what password they are referring to and there is no "forgot password" option. Can't move forward with the upgrade. Can someone point me in the right direction? Thanks.
- William10aJun 30, 2017Master
You are not doing anything wrong it is Netgear issue they were having try now it should be fixed by now.
- tltoJun 30, 2017Aspirant
Thanks for your response William10A. Unfortunately, the issue is still there. Will try again tomorrow,
If you have firefox internet explore it may work I get on to netgear's with firefox when microsoft internet explore fail to work.
