shax
Dec 07, 2020Follower
Firmware update fail Ex6120
Tried to update firmware. It wouldnt update. Now the green power light continues to flash and there is no network available. Nothing is working.
1 Reply
I would start with a factory reset.
Push and hold reset for 7-15 seconds while the devices is powered on.
If that doesn't work, you might have a corrupt firmware issue. In that case you can try using tftp or nmrpflash to recover it.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
