Skinni39
Mar 29, 2021Follower
Firmware update for R6120
I just went to download the files to update my netgear and when I opened the file all I got was a picture and user notes. Where do I get the actual updates I need. Thank you.
antinode
Mar 29, 2021Guru
> [...] all I got was a picture and user notes. [...]
"a picture"? Not likely. A file with a ".img" type? What led you
to believe that that was "a picture"? Did you read the "user notes"?
Follow the instructions therein?
> [...] Where do I get the actual updates I need.
You probably have them, but the non-psychics in your audience can't
see what you have.
