HardcoreMatt
Oct 06, 2017Follower
Firmware update issue and iPhone
I completed The firmware update, and the subsequent factory reset. Now, on my iPhone 7 with iOS 11 I am continually asked to insert username and password to access any Internet site nor can I use ap...
- Oct 11, 2017
Hi HardcoreMatt,
1. What is the firmware version of the router?
2. Does the issue persist on your wired devices?
3. Please try disconnecting all your wireless devices from the network then go through the reset process and reconfigure the router with a single wired computer. Reconnect the devices one by one and check if the issue persists.
Dexter
Community Team
DexterJB
Oct 11, 2017NETGEAR Moderator
Hi HardcoreMatt,
Dexter
Community Team
- DexterJBOct 15, 2017NETGEAR Moderator
Hi HardcoreMatt,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
