brian1388
Mar 14, 2023Initiate
FIRMWARE update R6220
I have been trying for two years to update my firmware to the latest version, and all I have is issues. My version is ancient, and I really want to get it current. When I download it, I open it and I...
Mar 15, 2023Guru - Experienced User
A lot of people double click on the extracted file and expect it to install.
You don't do that.
Once its extracted, you log into the router and upload that file to the router as detailed in the manual update process Kitsap posted.
Did you do that or did you try opening the file?
michaelkenward
This seems to be especially common among Mac users.
And it doesn't help that Netgear sometimes uses and .img file and at other times a .chk files. Both have very different alternative uses as file extensions.
Most Netgear manuals tell people what to do. But users seem to be a reluctance to go to the trouble of reading that stuff. Hence the constant flow of similar messages here.
