Daddyo70
May 05, 2022Initiate
Firmware update R6400
It does not let me do the firmware update On the Netgear nighthawk app It says it does it but it goes back and it has the same version I don’t know what to do
May 05, 2022Guru - Experienced User
have you tried manually doing it with a pc?
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
what version are you currently on?
Daddyo70
V1.0.1.76 It tells me that it’s updating but I’ll go back it says The software was updated successfully but it goes back to the same thing
