Log-Dog
Oct 21, 2017Aspirant
Firmware update
I'm trying to upgrade firware but something's wrong. Tried autoupdate and also tried to reset to Factory Defaults and manually update. Still says that new firmware upgrade is available.
- Oct 31, 2017
It looks like that we have a typographical error on that update.
The correct firmware version is 1.0.1.10 for JR6150 and R6050.
The download page and the server will be corrected accordingly.
michaelkenward
Oct 22, 2017Guru - Experienced User
There is a manual for the JR6150 along with the latest firmware at the end of this link:
>>>> JR6150 | Product | Support | NETGEAR <<<<
See page 1904.
The release notes for the software also tell you how to apply the firmware manually.
JR6150 / R6050 Firmware Version 1.1.0.10 | Answer | NETGEAR Support
- Log-DogOct 22, 2017Aspirant
Did you read that I wrote? I already tried to do it manually.
Can you give me the link to 1904 page, because I can't find it.
- michaelkenwardOct 22, 2017Guru - Experienced User
Page 190.
I did read what you wrote but your description did not tell us what you did and where it went wrong.
Which version do you have installed?
Which version are you trying to install?
See attached screenshot
