corvairbob
Mar 26, 2019Tutor
firmware update
i get an email that tells me i have a firmware update and so i connected this router up to see if the update would let me use this router with my c3700 combo and it dosen't do the update. the router ...
- Mar 26, 2019
thanks that must be it. i was talking about the r6300 router not the modem combo. so it them is up to date. but the issues it is giving me now means i will be just turning it off. it seems all my devices are still connected to the c3700 and 1 to the r6300 but my tablet showing my cameras now drops the video feed all the time. i connected it back up to see if it had an update coming it may stop this but it has not. so i will jsut get another combo unit and then not have to worry about my devices switching back and forth. thanks
Mar 26, 2019Guru - Experienced User
which router are you attempting to update? The C3700 is a modem/router combo and the firmware comes from the ISP not from the owner. so you must be talking a different device.
You might have gotten the email stating to upgrade the firmware but over the last month there was a bunch sent out that already had up to date firmwares. They're a good reminder but don't necessarily mean you weren't already on the latest firmware.
- corvairbobMar 26, 2019Tutor
- plemansMar 26, 2019Guru - Experienced UserMake sure your r6300 is in AP mode.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode-after-I-ve-already-run-setup
And then name the wireless names different than the c3700. Should prevent the switching around between the 2.- corvairbobMar 26, 2019Tutor
thanks i will check out that link. i'm not sure aobut the names one is netgear92 and one is netgear07 that is about all i know about naming them. and of course they have different passcodes. i did change the admin passcode on both of them
so i went to that link and in advance and wireless i do not see an ap box to check on the r6300 router or the c3700 combo unit. i used the netgear genie to configure the r6300 to my system i figured that would take care of all the necessary settings.
update i found the ap check box i had to check another box to get that ap to show. then i checked it and now i can't log into that router. my phone says it is now disabled. so what is going on now? i guess i now have to factory reset it.
thanks
