Retired_Member
Sep 12, 2020Firmware update
My Netgear R6260 AC1600 is prompting for a firmware update. Currently it is using V1.1.0.66_1.0.1 Acording to the Netgear downloads page V1.1.0.64 is still the latest version. I asked about this and...
AHortin
Sep 26, 2020Initiate
I just received this Firmware notifcation as well. I don't run Funjsq or any type of download accelerator software on my computer so I went ahead with the update. I manually downloaded the firmware file from the Netgear support pages, and after logging into the router, I went to the Advanced tab and then the Administration > Router Status menu option and clicked the Rebbot button to reboot the router. After rebooting, and logging back in, I went to the Administration > Firmware Update option and manually selected the .img file that I extracted from the Firmware zip file that I downloaded, and then uploaded the file.
The Firmware update proceeded without any issues. It took a few minutes to update, but once it was done the router rebooted again and it waas back up and running without any issues.
- RobinLKSep 27, 2020Aspirant
Many thanks for your helpful info AHortin. I've now downloaded the update and will do the same as you. Please can I ask you to post back in a few days with an update? Hopefully, you will have no issues to report! I will do the same after I've upgraded manually to v1.1.0.76.
