type36lotus
Apr 10, 2022Tutor
Firmware upgrade DHCP
Will be updating to firmware 1.1.0.112, from .84(?). Will DHCP assigned IP addresses change when this process completes? I have VoIP phone system where the routing of calls to individual phones ...
- Apr 10, 2022
It shouldn't.
but you can always go in and set reserved IP addresses. Pretty simple to do.
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
type36lotus
Apr 10, 2022Tutor
"It shouldn't." That is what I am hoping for. My concern is that if it does assign new IPs I will disable two law offices. They will not be happy. I do have a plan for a future implementation to assign all phones fixed IP addresses from a consecutive range. I am going to take your advice and define each phone's current MAC addr and IP address as reserved. It won't look neat, but should do the job, certainly better than being surprised when the IPs move around.
I will update with results.
Mike
type36lotus
Apr 16, 2022Tutor
The results are in and mixed. I did reserve(aka fixed, static) all the VoIP phones IP addresses to their respective mac address. This worked as it should phones retained their earlier assigned IP addresses. The DHCP devices were possibly random, but maybe not. Some retained the pre-update IP address, some did not. I need to check a device which retained its IP addr. and one that did not. At one time I needed to uncheck the NIC properties "Allow the computer to turn off this device to save power". This very much so kept the machine for obtaining new IP addr during sleep/lock states and the software accessing the device from failing to connect(it was saving the last IP used address).
- type36lotusApr 23, 2022Tutor
Made a visit to the office to check on the state of the network adapters. None were configured to keep the network adapter alive when in sleep/lock states. I am sure that there is a reason some changed IP and some did not, just not apparent to me. maybe IP lease duration? So Plemens advice was the prudent way to go and resulted in a successful firmware update . Maybe someone in network land with deeper experience than mine can explain why some changed IP, some did not.
