ManfredLS
Dec 04, 2018Aspirant
Firmware upgrade on WNR2000v5 from 1.0.0.34 to 1.0.0.70 failed
When trying to upgrade the firmware of the WiFi Router Netgear WNR2000v5 from 1.0.0.34 to 1.0.0.70 either by the web application (via routerlogin.net) or by the local Genie app I encounter an erro...
- Dec 05, 2018
> What other problems might cause this issue?
Corrupt firmware? You may be a candidate for the TFTP recovery
scheme. See, for example:
https://community.netgear.com/t5/x/x/m-p/1622096
antinode
Dec 04, 2018Guru
> [...] upgrade the firmware of the WiFi Router Netgear WNR2000v5 from
> 1.0.0.34 to 1.0.0.70 [...]
You might try a smaller jump. (The phrase "binary search" leaps to
mind.)
- ManfredLSDec 04, 2018Aspirant
Thank you for your reply. There is no other firmware version available in the download section of the concerned model. And when I try to do the automatic firmware upgrade without supplying a particular version and simply letting the system look for a matching version the error is also produced. Perhaps you could give me some guidance on how exactly to do the smaller leap.
- antinodeDec 04, 2018Guru
> [...] There is no other firmware version available in the download
> section of the concerned model. [...]
Look again (further down)? Visit http://netgear.com/support , put in
your model number, and look for Downloads. (For older versions, under
Firmware and Software Downloads, look for "View Previous Versions".)
Find the kit(s). Download the kit(s) you want. Read the "Release
Notes" file for instructions.- ManfredLSDec 05, 2018Aspirant
Thank you for the instructions.
Unfortunately not even the smallest jump (from 1.0.0.34 to 1.0.0.42) is possible. When attempting the error message is exactly the same as for the current firmware version (see attachment).
