SuzieSmith
Feb 08, 2017Aspirant
Firmware upgrade possible ?
The model is : Netgear N300 wireless ADSL2+ modem router DGN2200v4 I am currently running firmware version V1.0.0.24_5.0.8 The 'firmware upgrade assistant ' says ..... a 'router firmware u...
- Feb 09, 2017
SORTED ......
thank you you very much Michaelkenward ..
the zip/unzip app has opened the file in iCloud through airdrop
many many thanks you you guys are wonderful ......did you all know that ???
Gee ...it's great ...I shall now proceed with the firmware upgrade
thank you thank you 😃😃😃😃😃
netwrks
Feb 08, 2017Master
Software found under downloads - upper right on this page - https://www.netgear.com/support/product/DGN2200v4.aspx
