SuzieSmith
Feb 08, 2017Aspirant
Firmware upgrade possible ?
The model is : Netgear N300 wireless ADSL2+ modem router DGN2200v4 I am currently running firmware version V1.0.0.24_5.0.8 The 'firmware upgrade assistant ' says ..... a 'router firmware u...
- Feb 09, 2017
SORTED ......
thank you you very much Michaelkenward ..
the zip/unzip app has opened the file in iCloud through airdrop
many many thanks you you guys are wonderful ......did you all know that ???
Gee ...it's great ...I shall now proceed with the firmware upgrade
thank you thank you 😃😃😃😃😃
netwrks
Feb 08, 2017Master
Software found under downloads - upper right on this page - https://www.netgear.com/support/product/DGN2200v4.aspx
SuzieSmith
Thanks Netwrks Master .....been there .....no good .🙁
as I am only on an iPad Air I'm thinking I'm limited and it isn't allowing me to open the download in Safari , Viber , Firefox or email to myself . I did get as far as 'browse' in one of them but then it wanted a ....*cx file ...... or something so then I was lost !
any other suggestions ?
- VE6CGXFeb 08, 2017Master
When try to scroll down the update page, what happens? Are you clicking the right arrow?
- SuzieSmithFeb 08, 2017Aspirant
No right arrow here .... if this is the routerlogin.net website you are talking about where I can't scroll down on the 'router upgrade assistant ' page . The bottom of this page seems to be behind a HELP and SUPPORT panel along the bottom of the screen ...... and the screen does not want to allow me to scroll up to get to the bottom of the page on upgrading my firmware .
like the page is frozen on the screen , won't go up or down .
kylie
- sir_bazzFeb 09, 2017Apprentice
SuzieSmith wrote:Thanks Netwrks Master .....been there .....no good .🙁
It should be asking for a .chk file.
Here's the direct link to the frmware.
www.downloads.netgear.com/files/GDC/DGN2200V4/DGN2200v4-V1.0.0.76_1.0.76.zip
- michaelkenwardFeb 09, 2017Guru - Experienced User
Remember, you have to unzip the file to get at the chk file.
I mention this only because in the past people have tried to flash their hardware with the zip file. It doesn't work.
- SuzieSmithFeb 09, 2017Aspirant
Thanks Bazz ...... and this brings me to the zip thingy and t Michaelkenward says I need to unzip .
ok guys .....how do I do this ?
remembering I have an iPad Air .
Hmmm. Is there a Zip app in the iStore?
Or find a friend with a PC/Mac that can unzip it and hand over the firmware?
Maybe this?
How to Open Zip Files on an iPhone or iPad
or
iZip - Zip Unzip Unrar Tool on the App Store
First, can you confirm that you have been able to get into the web interface for the DGN2200v4? Can you navigate to the page where it asks you for the firmware?
I'd do a dry run of that, if you haven't already, before going to the hassle of getting zip software.
